Hello everybody,
y have full version of Ulead Movie Factory Disc Creator 4 and y want to ask one question.
When y insert file mpeg2 8000 bitrate, does ulead 4 work re-encoding video.
My film has 8800 bitrate and in ulead at default stay 7000 bitrate.
Y dont want to re-encode video, y just want to make a dvd menu.
So question is, will ulead 4 work re-encoding video if y insert mpeg2 file with 8800 bitrate
tnx
If your video is DVD Compliant, and you want to use it without re-encoding, put a check in that box that says "Do not convert compliant mpeg files"
George -
ok y know that, you think if my dvd has 8800 bitrate that is no problem to work with ulead 4 because in ulead wrote 7000 bitrate max
tnx -
mpeg audio.Y know that ulead work re-encoding audio, but does ulead work reencoding video with 8800 bitrate?
if your video is dvd compliant, it will use it the way it is as long as you check that "Do not convert compliant mpeg files"
It doesn't matter if the template says 7000. If you check that box, and your video meets dvd specs, it will use it the way it is (no re-encoding).George -
ok thanks, for 2 hour from digital camera in mpeg 2 with 8800 bitrate, ulead 4 movie factory works 15 minutes.Video is ok, no artefacts, so y am sure now that ulead 4 dosnt work reencoding if you put mpeg2 with high bitrate(in my case 8800)
thanks
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 21:42 -
Problems with Ulead Movie Factory
By merkuria_lyn in forum Authoring (DVD)Replies: 4Last Post: 25th Oct 2007, 14:12 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 11:59 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:20
