how do i make a bin file that has to be burned on a cd -r that is 850megs and won't fit on a cd -r. i eventually want to burn it on a dvd-r. can anyone give me some advice on this
Get a 90 min CD-R. Or wait until you put it on DVD-R.
To work with the bin, just like if you had burned it, mount it with daemon tools.
/Mats -
have you tried to burn it? A data CD has a lot of overhead due to error correction and fault tolerances, so the capacity is only 700 MB. A VCD does not have these, so the capacity is higher.
I say at least give it a try and see what happens.TANSTAAFL -
Originally Posted by waheed
/Mats
Help with large TS file
By mejallen in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2010, 19:44 -
Help to compress large HD File
By camlachie in forum Video ConversionReplies: 10Last Post: 10th May 2009, 12:47 -
large iso file
By fabpozzi in forum Authoring (DVD)Replies: 10Last Post: 13th Dec 2008, 12:10 -
Avi file too large for CD
By hitmanhill in forum Newbie / General discussionsReplies: 17Last Post: 22nd Jan 2008, 14:19 -
Large .dvr-ms file?
By ukcat in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 15:47
