HOPEFULLY I'm posting this in the right forum, my apologies, if I'm not.
I've downloaded plenty of material (musical performances, music videos, etc) from the net, and plan to put them on my own personal DVDs. In the process I'm re-encoding the majority of them from PAL to NTSC.
I use TMPGEnc. When I'm converting them, using their DVD NTSC template - when I get to the last step - should I lower the encoding bitrate? I mean, there's no reason for the bitrate to be of dvd quality, when the source videos may only be SVCD quality, correct?
I ask, only because if I were to lower the bitrates, to the standard SVCD rate, or a bit higher, and create smaller sized video files, I'd obviously be able to fit alot more videos, and footage onto each disc. I just want to make sure this won't backfire on me, and I lose all my original videos.
Thanks for any help!
~Michael
Encoding at even the same bitrate will, in all likelihood, reduce the quality. Determine how much footage you want to fit on the disk (total runtime) and calculate the appropriate bitrate. If you feel you can allocate a lower bitrate to some parts in order to up the bitrate in others, do so. However, remember this. By using the DVD template, you are increasing the resolution. If you maintain the same bitrate as it was for an SVCD, you will reduce quality. There is no way around this. Higher resolutions require a higher bitrate as more data needs to be transfered.
The only way to know for sure if you will be happy is to test it out. Encode a representative clip at different bitrates, then compare them by authoring a disk. Then you will know what works for your setup.Read my blog here.
First: keep copies while you experiment
Second: As long as your clips meet DVD specs ( look on the left under "WHAT IS" DVD ), then they should be fine. There is no reason to take a PAL 352x288 mpeg1 clip and turn it into a NTSC 720x480 mpeg2 clip. Keep the resolutions and bit rates similar and all should be good.
I've have heard of some players having issues when multiple different file formats are on the same disc.Google is your Friend
16:9 Material on a 4:3 DVD to be displayed on a 16:9 monitor
By willy4360 in forum EditingReplies: 5Last Post: 10th May 2010, 07:40 -
deinterlace miniDVD and miniDV material before (re)encoding to DVD or not?
By Massa in forum Video ConversionReplies: 3Last Post: 2nd Jan 2009, 13:54 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 07:56 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
question about downloaded DVDRips
By Mowie666 in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2007, 22:56
