I would like to make a HD Dvix file above 720x480 res to play back on a DVDR in HD.
I read the manual on the Linkplayer2 and it said the max bitrate is 1.5m but not the Max resolution for playback for Dvix files.
My question is will the Linkplayer2 play a Dvix file from a DVDr above 720x480 in HD?
thanx in advance,
Chas
Hi-
Yes. It'll play resolutions up to 1080i and 720p. Also, it handles bitrates much in excess of 1,500. I don't know for sure, but it has to be 6,000 or more. Otherwise it wouldn't be much good at playing back Hi-Def files. -
According to the DivX webpage, the player supports 720p and higher. They also list the bitrate at 720p at 4MBs.
http://www.divxnetworks.com/solutions/hd/faq.phpGoogle is your Friend
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
