Is there a way or suggested software that can take a dvd recording and "edit" the menus, for instance, where it has been authored with the word "killer" and it should be "driller".
I only have the dvd. none of the files or saved format from the original author software.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
It depends how the test is done on the disk. If it is embedded in the image (e.g. put in in photoshop then just dropped into the background) then you need to extract the image, change it, and reencode and slip it back in.
If it is a subpicture, then you need to be able to edit the subpitcure and reinstert it. Something like menuedit or DVD Remake Pro might allow you to change subpictures. IFOEdit or PGCEdit might allow you to replace the background. Look up these tools and their associated guides for details.Read my blog here.
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 13:44 -
Error BD REBUILDER menu are not seen titles after the compression.
By malpa in forum Authoring (Blu-ray)Replies: 0Last Post: 6th Jan 2010, 22:18 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
menu error
By stitch2005 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 19th Dec 2008, 04:19 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
