I have some raw DV footage that I would like to compress.
So far, I'm finding this very hard to do.
The footage I'm compressing should give me a very small file as it's just interviews of people with no rapid movements or scene changes.
Instead, I'm getting 20 - 40 MB files for about 20 minutes footage.
(Also, this isn't even full screen size, just 500 x 400.)
I've tried two software programs.
The first is Ulead Studio.
So far this has given me the best results.
I can at least do SOMETHING: i.e. at least end up with a good quality (big in size) compressed video file.
The other software is Adobe Premiere.
So far I have found this to be very poor!
(I'm a very novice user - only started using it a few days ago.)
If I create a video file with no compression, the footage is fine.
If I go for a compressed video, it just comes out mangled!
What am I doing wrong?
What compression should I be using? Is it possible to get other algorithms into my programs to give the same compression as divX say?
IMPORTANTLY I need to take the video into Flash and export it to make a Flash video file.
I'm not sure if there will be a problem with Flash reading the video if it's divX or Xdiv.
(I haven't actually tried this yet though.)
Any help with the above would be appreciated.
Thanks.
Jam
Is your goal maximum compression?
How important is quality?
Do you want it to play on a DVD player?
In Premiere, what format were you compressing to? There are many. Which version Premiere?
Which compressor did you use in ULead Video studio to get to 20MB? Was it WMV?
There are tradeoffs for each format. Give us a better understanding of your goals for this video.
For Ref:
20 min of DV is about 4.3GB.
20 min of DVD MPeg2 is ~ 245MB to 1.5GB
20 min of VDC MPeg1 is ~ 190MB -
The typical rule for compression is the highest quality input (i.e. DV) will produce the best compressed video quality. Why not go from edited DV to Flash directly?Originally Posted by jammer20002
http://www.macromedia.com/devnet/mx/flash/articles/flv_howto.html
http://www.macromedia.com/devnet/mx/flash/articles/video_primer_02.html#thirdparty -
edDV thanks for the replies.
it's been sooo useful.
u've at least solved my problem.
before: i was compressing video and then converting to flv by importing into flash and then exporting.
i'm now using sorenson squeeze.
that's solved a LOT of problems.
and i'm getting amazing quality.
(i had to play around a bit in the begining, but i'm getting the hang of it.)
Capturing video and compressing at same time
By tyder26 in forum Capturing and VCRReplies: 15Last Post: 3rd Aug 2011, 06:18 -
converting/compressing video
By govtphish in forum Newbie / General discussionsReplies: 4Last Post: 16th Oct 2007, 01:56 -
compressing a video
By Shotobits in forum Newbie / General discussionsReplies: 1Last Post: 15th Jul 2007, 11:18 -
Compressing DV video
By Duncan1382 in forum Newbie / General discussionsReplies: 14Last Post: 14th Jul 2007, 16:21 -
Having problems compressing AVI file
By nucklhead24 in forum Newbie / General discussionsReplies: 6Last Post: 17th May 2007, 22:42
