    Nov 2002
    Italy
    Hi,
    If I upload in ProExtensions my video file (m2v + mpa), Play, press Stop, image freezes, sound goes and mouse remains busy.
    I posted the file log in the DVD Lab forum, and they told me something is wrong with my DirectX installation because under "Inserted Filters" there should be an entry for a sound output device and this should be either DirectSound Renderer or Waveout Renderer.
    My PC is regularly updated by WindowsUpdate, however, to be sure, I have reinstalled the DirectX 9c, but nothing changed.
    I have no toher problems with any other application.
    I work on WXP PRO SP2
    Maybe somebody can help me here??
    Here's the log:
    DVD Lab PRO Extensions
    Version 1.0 - 1.1.0.395
    venerdě 3 giugno, 2005
    00.29.47: Reading index file for "M:\My Videos\Video 8\MPEG2_DVD_PAL(Mastering).m2v"
    00.29.48: The number of Index entries for "M:\My Videos\Video 8\MPEG2_DVD_PAL(Mastering).m2v" is:151208
    00.29.48: Reading index file for "M:\My Videos\Video 8\MPEG2_DVD_PAL(Mastering).mpa"
    00.29.49: Inserted filters:
    Default DirectSound Device
    MPEG Audio Decoder
    MPEG-I Stream Splitter
    00.29.54: Chapter Point added at Frame 0 (0:00:00:00)
    00.29.54: Video = MPEG2_DVD_PAL(Mastering).m2v
    Resolution = 720x576
    Aspect Ratio = 4:3 - Normal TV (DVD Video compliant)
    Frame Rate = 25
    Bit Rate = 8000 Kb/Sec
    Running Time = 1:28:55:05
    Frame Count = 133381 (0 ... 133380)
    VBV Buffer Size = 224 KB
    Profile/Level = Main / Main
    Interlaced or Progressive = Interlaced
    Colour Format (Chroma) = 4:2:0
    Low Delay = No
    GOP Length & Structure = 17: IBBPBBPBBPBBPBPBB (8913 GOPs)
    Frame Type = I
    DC Precision = 9
    Frame Structure = Frame
    Top Field First = No
    Audio = MPEG2_DVD_PAL(Mastering).mpa
    Encoding = MPEG1 Layer 2
    Bit Rate = 192 Kbits/Sec.
    Sample Rate = 48000 Hz.
    Channel Mode = Stereo
    Running Time = 1:28:55.223
    Frame Count = 5335224
    Thank you
    Alex
    AOPEN AX34, PIII 1.0 GHz, 1,5GB RAM, HD WD 120 GB, Pioneer DVR-116D, Plextor PX-716A, HIS Excalibur Radeon 9600, 256Mb, 2xMonitor Philips 109P20 Br Ethernet D-Link DE-828CT, Philips ToUCam Pro, WXP PRO SP3
  2. Don't double post.
    Cheers, Jim
    My DVDLab Guides
