i have a avi file that i want to burn on a dvd but its to long. the file is 4hrs and 40 minutes, i want to cut it in half so i can fit it on to one dvd. whats the best programme to do this... ..........also i have a mpeg clip that freezes at a certain point so i tried to use video redo to cut the bad part out , but every time i try to load it into yhe video redo programm it freezes . any ideas on how i can fix this or is thewre somrthing else i can use. any info on these 2 problems would be great........
Your AVI file; Do you mean you want to fit on 2 DVDs? Anyway, VirtualDub works as well as any for cutting AVIs. Just cut on a key frame and save the two parts.
For MPEGs, there are a few utilities for repair in the 'Tools' section to the left. For MPEG editing, you can use Cuttermaran for free. I haven't used it, so I'm not sure how well it works in repairing. -
For one DVD, that would give you a bitrate of ~1929Kbs. A little low for full resolution DVD. You could try 1/2 D1, 352 X 480, or similar to VCD resolution. Not the best quality, but that depends on how good your source video is. I got that from a bitrate calculator in 'Tools' to the left. <<<. No need to cut the AVI, unless you have FAT 32 and you can't get a 4GB+ file on your HD.
EDIT: You know you might want to try VSO DivxToDVD. It will do the hard part of the conversion to DVD. If you don't like the results, then the 'hard way' is what you need to learn. -
when i try to put the biterate at 1932 it jumps back up to 2000. how do i get it to stayat 1932.
Depends what encoding program you are using along with what settings. With TMPGEnc you can just use the DVD template NTSC (Low Resolution) from the wizard and it will figure it out for you. But the setting shouldn't change if you select it.
BTW, that bitrate can vary, but with the length of your AVI, it should be below 2000. You might want to encode a 5 minute section to see how it will come out. Low bitrates tend to have low quality, that why I suggested 1/2 D1. For more information, you will need to read the guides. <<<
Or try the VSO DivxToDVD program if you don't need as much control.
AVI Videos Cutting Out
By Blade of Tyshalle in forum Newbie / General discussionsReplies: 11Last Post: 8th Feb 2012, 12:49 -
Cutting Ripped AVI
By quxote in forum EditingReplies: 4Last Post: 24th Feb 2008, 13:47 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 06:53 -
help cutting an AVI file
By ethandeitrich in forum EditingReplies: 2Last Post: 24th Oct 2007, 00:25 -
Cutting AVI without all the re-encoding
By gameroftheuk in forum EditingReplies: 6Last Post: 31st Aug 2007, 22:13
