I'm getting ready to attempt to convert an Xvid avi to DVD. I've never authored a DVD before and my computer is pretty old, so I'm hoping to only have to do it once. I would appreciate advice on getting the settings correct.
My source movie is 640x272 25fps, ac3 audio 48000 Hz 192 kbs.
I need to convert to NTSC. So I believe I should:
Encode with mpeg2enc, set size to DVD, frame rate ntsc film, enable 3:2 pulldown, set audio to encode passthrough.
Sound good? Also, does it matter if decode with Quicktime or mplayer? Should I check Letterbox?
Much thanks for any and all advice!
Make sure your movie plays with sound in Quicktime Player. You may need to install the ac3 codec from http://www.insaneness.com/ac3.html
Enable "Decode with Quicktime", don't use Passhtrough, enable Letterbox.
Advice on DVIX/Avi dvd players
By aelfheah in forum DVD & Blu-ray PlayersReplies: 15Last Post: 27th Jan 2011, 17:48 -
DVD to AVI ideal settings
By jbaruch76 in forum DVD RippingReplies: 11Last Post: 4th Nov 2008, 17:40 -
Best settings to use when converting AVI to DVD for 624x464 files?
By Cobra281 in forum Newbie / General discussionsReplies: 5Last Post: 26th Sep 2008, 17:45 -
Convert AVI to DVD best method advice required please
By vwgolfman in forum Video ConversionReplies: 7Last Post: 1st Apr 2008, 11:01 -
AVI to DVD looks all pixeled. Advice?
By tmac2085 in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2007, 21:56
