  1. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    In dvdshrink when re-authoring under where you choose language ithen says subpicture. What the hell is the subpicture and do i need it?
    What We Do In Life, Echoes In Eternity....
    Dec 2004
    Australia
    Subtitles. No idea if you need them or not.
  3. Subpicture is a generic term that covers subtitles, the buttons in button-over-video (BOV), and other overlay graphics (translations for foriegn-language signs for example).
    It's up to you if you want to keep them or not. Subpictures rarely take up much room, so you won't gain much by removing them.
  4. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Ok I was just confused if they were the subtitles or some sort of actual video that was needed. Why didn't they just use the word subtitles instead of subpicts......lol
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Because they are called sub-picture in the design spec. They may also be things other than subtitles, including meu overlays or other graphics. If you have the original Matrix DVD it has a feature called 'Follow the White Rabbit'. While you watch, a white rabbit appears in the corder of the screen Press the Enter button and you get a small clip of behind the scenes footage. The rabbit is a subpicture.
    Read my blog here.
