  1. I have two DVD drives in my computer. When I copy disc to disc, Nero first creates an image of the file, then starts the burn. This takes twice as long. On my friends computer when he does disc to disc it starts burning right away and does not have to create an image first. Does anyone know if there is a way around this? Any help appreciated.
    Boxingjunkie
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    It's called "On The Fly" or "Quick Copy". When you select "DVD Copy" or "Copy Entire Disc", there should be a tickbox called one of the above. If you tick it, it won't create an image on your hard drive first.
    Nero Burning ROM:
    Nero Express:
    Personally I'd use DVDDecrypter ISO Read / ISO Write, as I've had issues in the past with Nero's Copy Disc "feature" when copying DVDs.
    If in doubt, Google it.
