Hi, i'm capturing stuff off tv onto my mac. i'm capturing in mpeg4, but there seems to be a strange quicktime thing with this where the audio doesn't sync up with the video properly, i.e. the audio finishes about 10 frames before the video. so i've been extracting the audio and pasting it back into the video using the add and scale function in quicktime pro. the the audio syncs up right to end, cause it scales it to fit the length of the video. but then when export the video from quicktime using divx 5 the audio goes back out of sync. worse than before. so i wanted to try using ffmepg. but because the audio isn't embeded, i.e. self contained, in the file, ffmpeg wont read it. so i have been trying to use the 'add audio' function in ffmpeg, but it never outputs any sound. how do i use this feature? i've tried everything i can think of. PLEASE HELP!
To use this feature you should just select an external audio file and not use "Decode with Quicktime". In case of problems you may email me to major4@mac.com with your process output (blue "i" icon).
when i try using a .wav or .aiff file it just says:
'No audio or video streams available'
here's the whole ouput:
Encoding started on Wed Jun 8 12:16:37 BST 2005
Input #0, yuv4mpegpipe, from 'pipe:':
Duration: N/A, bitrate: N/A
Stream #0.0: Video: rawvideo, yuv420p, 752x416, 25.00 fps
Output #0, avi, to '/Volumes/work/video/alchemyTV/testselfconnoaudio.mov.ff.avi.e.avi':
Stream #0.0: Video: mpeg4, 752x416, 25.00 fps, q=2-9, 1756 kb/s
Stream mapping:
Stream #0.0 -> #0.0
bench: utime=1.321s
video:1036kB audio:0kB global headers:0kB muxing overhead 0.688992%
Input #0, mov,mp4,m4a,3gp, from '/Volumes/work/video/alchemyTV/testselfconnoaudio.mov':
, start: 0.000000, bitrate: 10351 kb/s
Stream #0.0: Video: mpeg4, 752x576, 24.99 fps
If the source is a .mov file then 'Decode with Quicktime is forced automatically to avoid a ffmpeg bug with Quicktime files. You may try to use "Mux as.. AVI" to combine an AVI file with an audio track.
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 22:59 -
How will an MP3 audio file will compare with a AAC audio file?
By ConverterCrazy in forum AudioReplies: 6Last Post: 31st May 2011, 03:01 -
How to merge audio file(mp3) and a video file (flv)
By suresh3484 in forum Video Streaming DownloadingReplies: 0Last Post: 20th May 2008, 01:15 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31
