i hve just tried to d/l real player,during installation it says it can not complete as i am not system administrator and cant access windows registry,i am using xp,and always logged on as an admistrator- does any body have any clues??
Sounds like RP has a problem. Just my opinion, but I wouldn't use it anyway as I consider it spyware. Why not try Real Alternative player. It works the same but doesn't come with all the added crap of RP. If you insist on Real Player, try downloading it again.
You aren't on a corporate network are you? If you are, and your network uses Active Directory, the Sys Admins may have made a Group Policy Object that blocks/prevents real player from being installed. These GPOs override your local machine admin rights. If not, disregard that. I see you're using XP. If you have SP2 installed, allow real player through the firewall, or turn it off until after the install is complete.
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
login as administrator W7?
By neworldman in forum ComputerReplies: 1Last Post: 18th Mar 2010, 10:30 -
How to log in as administrator in Windows 7
By jyeh74 in forum ComputerReplies: 7Last Post: 8th Feb 2010, 00:58 -
Network Administrator Ratio
By oz_surfer in forum ComputerReplies: 3Last Post: 23rd Sep 2008, 10:16 -
xp administrator rights?
By edong in forum ComputerReplies: 5Last Post: 9th Aug 2008, 16:25
