I have this avi movie but its not very sharp in images has a few bloky images is there anyway to smooth that out and sharpen it?
thanks
CrisCr0ss
Results 1 to 9 of 9
Most editors have a sharpen filter but that will just exacerbate the issue with the blockiness. The blockiness is called macroblocking and is caused by a low bitrate. Essentially most of the video data is gone. you can't fix what's not there.
You can remove the blockiness by reencoding at a higher bitrate with a soften or a blur filter but that will result in more detail loss where there is no blockiness. -
so in other words its beter not to play with it, cuz itl only get worse
Nothing wrong with experimenting.... Just find a part that's bad and trim it so it's short and work on that. Save you a lot of time.Originally Posted by CrisCr0ss
Double deinterlace and heavy NR.
But that'll soften it.Want my help? Ask here! (not via PM!)
You can try a filter chain on virtualdub. Then you judge if it is worth it
MSU_Deblocking to de-block
MSU_Smart Sharpen (overall & boarders) to sharp it
AVStoDVD Sharpen
By djgazzabhoy in forum Video ConversionReplies: 2Last Post: 29th Nov 2011, 07:34 -
How to use sharpen filters with Avisynth & MeGUI??
By jeticson in forum DVD RippingReplies: 10Last Post: 28th Aug 2011, 09:40 -
Is there a relatively simple program to sharpen up a VHS capture?
By Prynter in forum RestorationReplies: 4Last Post: 18th Jun 2010, 14:35 -
sharpen your video
By sharmine in forum Newbie / General discussionsReplies: 3Last Post: 4th Feb 2008, 00:57 -
How can I enhance / sharpen this video?
By ferrous in forum RestorationReplies: 2Last Post: 22nd May 2007, 17:10
