Does anyone know why I have this problem? It is the fastest encoder I can find, but the video is choppy, and I can't figure out why.
Actually, CCE is faster, and the quality is better than the Mainconcept tsandalone product. However that does not answer your question.
What is your source (avi/mpeg ? resolution ? framerate ?)
What is your taget ? (DVD ? NTSC/PAL ?)
What si your process ? (Load and go ? Frameserve and filter ? Load and resize in main ?)
You haven't given us enough to go on.Read my blog here.
Avi always. unknown 25 fps.What is your source (avi/mpeg ? resolution ? framerate ?)
DVD NTSC.What is your taget ? (DVD ? NTSC/PAL ?)
frameserve and filter.What si your process ? (Load and go ? Frameserve and filter ? Load and resize in main ?) -
Probably because of the framerate conversion from PAL to NTSC.
Get a cheap player that supports pal and convert to PAL instead.
or
Use canopus procoder and convert to NTSC, it is better for that.
or
Change the avi to 23.96 fps with virtualdub and convert the audio to 23.976fps with besweet. and convert it to ntsc 23.976 with 3:2 pulldow.
or
Convert to NTSC but with 25 fps and use dgpulldown to change the mpeg to NTSC 23.976fps.
or
search for "ntsc to pal". -
Converted to pal it still is choppy video, canopus crashes durring conversion, and dgpulldown didn't work. I don't know how to convert to 23.976 fps with virtual dub, can you direct me to a tutorial?
If this is an XVID file make sure you have the latest codec installed on your system. Look in the tools section. Using an outdated XVID codec to watch or encode a film made with a newer XVID codec can cause the film to be choppy.
It doesn't matter who you vote for. The government always gets in.
How to convert WMP v9 (VC-1 Simple/Main) to divx/avi?
By ericdunn in forum Newbie / General discussionsReplies: 12Last Post: 28th Apr 2012, 18:09 -
Must i convert High@5.1 to Main@L4.0 , how and what settings ?
By G30 in forum Video ConversionReplies: 6Last Post: 25th Apr 2012, 13:18 -
Help with some video concepts
By GOH in forum EditingReplies: 11Last Post: 14th Dec 2011, 19:38 -
Convert main movie from DVD to TS.
By Puni in forum Video ConversionReplies: 4Last Post: 19th Feb 2010, 08:42 -
Help w/ understanding theory with converting from vob to mp4, concepts, etc
By kmxe in forum Video ConversionReplies: 10Last Post: 15th Feb 2010, 14:58
