Hi I'm trying to converrt an Mpeg2 file to DVD using WinDVD creator but I get the audio out of sync. It starts of ok but the audio after about 3 min gets a few seconds out of sync.
Is there a better program I could use that would fix this. Free or trial I don't want to pay for a program I'll only use a few times.
Thanks.
Is the mpeg2 source dvd compliant ? Try add it in tmpgenc dvd author and it will report if it is.
If not try use some other all-in-crap-one dvd converter like divxtodvd, nerovision express or see our tools list here to the left. -
Tried using TMPGE and got the same thing happen but further into the movie.
Is the audio in sync in the original MPEG2 file ? Demux the audio & video out of the MPEG file. Use the two ES assets separately in your DVD authoring software. This should, imo, solve your problem.
Use better tools like TMPGEnc DVD Author, DVD Lab etc.When I was born I was so shocked that I could'nt speak for 18 months.
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
DVD Flick audio sync problem?
By neo*2 in forum Video ConversionReplies: 4Last Post: 6th Sep 2009, 13:51 -
HD dvd conversion, audio sync problem...
By BigJeebz in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 21:52 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 04:38
