Results 1 to 9 of 9
  1. I am looking for a guide for DVDREasy. The one on afterdawn is not on line at this time. Read the reviews, got interrested, downloaded. No Guide, no clue. Is there another guide or is that one posted somewhere else? Thanks. ........................ harrymj3
  2. Send me a PM on what troubles you.
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  3. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    I had trouble installing mine. It wouldn't fine the CCE Executable file of the HC Encoder that came with it. So I gave up!
  4. Problem solved. I installed the 6.3 update to the 5.6 version and all is well now. I also installed the iso.exe file but don't think that mattered. I found the guide right on their site. Thanks for the replys. ................. harrymj3
  5. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    I want it to work! What am I doing wrong???
  6. shelby GT,
    I spoke prematurely, only worked once on a movie that didn't need to be reencoded. Can't seem to start muxman after HC finishes encoding process. Rumor has it that 5.8 is the version that works well. I am looking for that one at this time. .................... harrymj3
  7. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    Well I couldn't even really get past the install point. It asks you to point it to the HCBatch.exe file (if I recall correctly). I know the directory that is in, and go there, but it won't let me select it. Where am I messing up?
  8. shelbyGT, I never got any further with 5.6 than you have but when I installed the 6.3 patch that gets rid of the bitrate viewer it will work on movies that don't need reencoding but will not enter the muxman stage after HC or CCE is done. I have tried it with both encoders. The forum on the dvdreasy site will have more useable info on it. Check it out and good luck. ............... harrymj3
  9. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    After reading up on it a bit, I think I'm going to wait until a more stable/bug free beta comes out, then mess around with it. Is a very nice idea, I just am having too many problems with it right now.
