Hello all...
I was wondering if it's possible to make a copy of a DVD that was produced/made with DVDXCOPY using ISO.
I tried to do it, but I get a "bad disk" message. The tools I have are DVD Decrypter & DVDShrink.
Any help is appreciated.
Thanks...
Results 1 to 9 of 9
There is a sticky at the top of page covering this topic.
Google is your Friend -
Thank you for the replies....
I'm having trouble find the article/sticky about backing up a DVD made with DVDXCOPY using ISO. Or is the reference to use ISO to make a copy of the DVD in question?
Thanks...again... -
Ok...I'm doing as instructed, and DVD Decrypter gives the following message;
Unable to create, replace or append to file:
X:\dir\filename.iso
Reason: The process cannot access the file because it is being used by another process.
Nothing else is running; DVD Dcrptr is the only app besides XP.
Any ideas?
thanks again...
edit:
looking at the DVD; there are 2 folders and 1 txt file;
archive.txt (text about dvdxpress stuff;
audio_ts (empty /or in a format that I can't read???)
video_ts (10 files bup/ifo/vob);
can I simply create a new folder, copy the contents and then burn another dvd?
ok then... -
Yes. dvdxcopy has already removed css protection. You can copy the folder to your hard drive and burn to dvd. Dont bother copying the archieve.txt file. Only copy across the VIDEO_TS folder.
Use titlesetblanker or vobblanker to strip out the warning screen dvdxcopy made. -
After you have made a copy of a disc using (insert your software here), there is no need to rip the disc a 2nd time. All you need to do is use (insert your dvd burning software here) and make a disc copy. Copying the disc is much faster that ripping and authoring.
Also, at the top of this forum is a sticky called "Can I make a backup of a backup" which sounds like what you are asking.Google is your Friend -
Something's screwy with your system or DVDDecrypter setup. Or are you perhaps on a FAT32 system? DVDDecrypter can't read a full DVD to ISO under FAT32, as that will exceed the file size limit of the file system.
/Mats
Blu-ray disc structure to iso disk image
By llee782 in forum MacReplies: 2Last Post: 12th Feb 2010, 03:22 -
Using Pinnacle Studio 14 Ultimate Collection to create iso files (BD Disk)
By JensFudge in forum Newbie / General discussionsReplies: 4Last Post: 4th Jan 2010, 04:27 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 22:03 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 23:27 -
Copying Multiple VIDEOS onto ONE DISK.
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 30th Dec 2007, 19:30
