I am dealing with an avi without sound. GSpot give for codec and FourCC the information written in the title. I have last XviD (Koepi) instaled and the video can be opened (and played) in VDubMod just fine. Though through AviSource in avisynth it throw an error: AviSource: Could not decompress frame 0. This is maybe a codec problem or maybe avisynth problem I don't know. I am planing to reconvert the file through huffyuv and then to convert it with avisynth to mpeg. This is rather time consuming process, then I would ask for some solution and suggestions. Which codec I should use?
Hmm, I have thought also about DirectShowSource, but I do not want to use it if there is another way.
Thanks in advance.
Since VirtualDubMod has no problems with the file, Why don't you just frameserve from VirtualDubMod?
Problem solved!
Shortly - I tried huffyuv to see how much space it will take and encoded about 1000 frames. Viewing the encoded material i saw a green frame at the beggining of the clip (originally these 10-15 frames are black. Interestingly the green frame was not the first, but the second). Analysing the original in VDubMod show me that first frame is marked as [D] - delta frame? the beggining sequence is [D], [K], [], [], [K] ...... So I cut till the second key frame with VDM saving directly the remain. Now this new clip can be opened through avisynth without problems.
What is divx and xvid codec?
By Azrail in forum Newbie / General discussionsReplies: 4Last Post: 5th Oct 2010, 21:31 -
DivX and xVid codec
By cheerful in forum Software PlayingReplies: 9Last Post: 10th Jan 2010, 21:55 -
Is there a free DivX codec for Dr.DivX?
By Djard in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 03:33 -
Best free DIVX codec?
By DonGallego28 in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 18:45 -
Can't work with or find codec for "OpenDivx 4" files
By Lolipop Jones in forum Video ConversionReplies: 5Last Post: 14th Jun 2007, 15:43
