Results 1 to 11 of 11
  1. Hoe can I change the volume in AC3 file?
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Decode to wav, use audio editor like Goldwave, encode back to AC3
    /Mats
  3. But when I encode bacl to AC3 I lose the 5.1 channels =/
    if you are just going to play on your computer you can use ac3filter and use the gains the increase the volume.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Yes, if you go the simple route. But if it's really important to you, you can extract 6 mono wavs from the 5.1 AC3, increase the volume on each wav, then reencode to AC3. Unfortunately, I don't think there's any free 5.1 AC3 encoder.
    /Mats
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Can't besweet encode 5.1 ?
    Read my blog here.
  7. It can. . Though I tried to make 2 pass automatic max gain and in most cases it is 0.5 db. So really unnoticeable. It seems 6 wav way should be better, but you must decide which channels to gain - obviously under mixing the chanels back together you may have sound distortion if not appropriate gain is applied. Just some thoughts.
  8. Originally Posted by mats.hogberg
    /Mats
    I'm looking for something that does that. I want to split the file into its separate tracks and bring down the action volume while bringing up the speaking volume. I think they should mix the DVD sound more for homes instead of leaving the theater sound intact, or give you another sound track option. I hate when you constantly have to adjust the volume when it's late. Deja vu.
  9. You can use BeSweet to extract 6 waves from a AC3 file. You have to select "Six Waves" as the output. Then edit each file as you want before encoding again.
    When I was born I was so shocked that I could'nt speak for 18 months.
  10. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Even if you separate the tracks, don't be so sure the background sound and speech is separated. You're still in for quite some imaginative filtering, I'm afraid...
    /Mats
  11. Originally Posted by mats.hogberg
    /Mats
    ... Very true. Lot of effort is required. Better to increase vol of all channels and downmix to 2 channel AC3.
