Freinds,
I am trying to install the InterVideo WINDVD RECORDER 5 PLATINUM on my pc which is equipped with Windows XP Pro (SP2). But what the problem i am facing is when i try to install it, it says that WinDVD is already running and close it. But There is nothing running like that.
Even i restarted my pc and try to install it again, but It says the same too.
Please help me in it.
I also checked this ctrl+alt+del and there is nothing like that in processing.
If you have WinDVD installed, uninstall it. WinDVD recorder has DVD playback.
Vegas 10 Platinum Problem
By REDRUMxINxTX in forum EditingReplies: 6Last Post: 26th Jan 2012, 18:53 -
SONY Movie Studio Platinum 10 rendering problem!
By EagleW in forum EditingReplies: 4Last Post: 4th Nov 2010, 17:52 -
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 00:30 -
Getting audio desync problem when ripping with DVDFab Platinum 4
By godfist314 in forum DVD RippingReplies: 2Last Post: 8th Jul 2008, 13:50 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12
