Hi all i have some Avi files with ogg audio which my yamada player wont support so id like to convert the audio to mp3ive tried demuxing with virtualdub mod and coverting ogg to mp3 with free rip and adding it back in vdub mod and resaving with direct stream copy of video this has led to a slight auido sync problem anyone know of a better way to do this ???
thanks
did you export the audio to wav prior to converting it to mp3? did you convert it to vbr mp3 or cbr mp3?
i used the demux option in virtualdub mod , to save the ogg file them vonverted to mp3
Well I just created an avi with vorbis audio via ffmpeg and VDubMod wasn't able to extract anything usable. AVIMuxGUI which claims to support vorbis in avi just crashed and the only thing that could playback the avi was ffplay.
Perhaps this was created via an old NanDub build? Or via the ACM vorbis encoder? If so I would suggest that you just delete it. -
SKIPTRACER do you have lamemp3 plugin? I usually save not demux the audio with lame mp3 in the compression settings of virtualdubmod. Then add the new audio file back to vdubmod and save in direct stream copy. Never had sync issues.
“He who makes a beast of himself gets rid of the pain of being a man.” -
What i would recomend is demux using AVIMuxGUI (very easy to learn once u get the hang of it) once demuxed save the video w/o the audio. Make sure to keep backup. Convert the audio Via besweet or any Audio converter (dbpoweramp i think can) then remux via AVIMuxGUI
Note: if their are any audio sync problems open up Media Player Classic, load the .avi with the sync prob
view>options>Filters>audio switcher>
Check "audio time-shift (ms)" then add the amount of ms the audio is out of sync by
+1 is later
-1 is earlier
and remeber 1000ms = 1 second
hope this helps. -
Thanks for the advice guys , ill have a crack at it when i get home from work .
how do you convert .ogg audio file to mp3?
By shun in forum AudioReplies: 5Last Post: 22nd Sep 2023, 15:34 -
Remux FLV (AVI and MP3) to AVI without VFW?
By vbug in forum Video ConversionReplies: 2Last Post: 26th Mar 2010, 12:32 -
Trouble converting AVI(divx)+MP3 to FLV+MP3
By BLboy in forum Video ConversionReplies: 7Last Post: 21st Jul 2009, 04:36 -
How do I convert .MP3 to .OGG directly?
By Cobra in forum AudioReplies: 11Last Post: 9th Oct 2007, 14:04 -
Turn .ogg into .avi
By babellou2 in forum ffmpegX general discussionReplies: 8Last Post: 22nd Jun 2007, 05:46
