I bought the Avermedia EZ DVD Maker PCI card several days ago. The chipset is SAA 7130. The card works fine with the software in the same box, i.e. NeoDVDstandard 4. The highest resolution I can get is 720*480. However, the output file can only be mpeg. I need to do a lot editing, so the avi format is prefered for me. So I tried many other captiure softwares, including windows movie maker, VirtualDub and VirtaulVcr. However, none of them can capture video with full resolution. Only 320*240 can be achieved. Anybody know how I can fix this problem? I appreciate your help.
I did some research before posting. This question has been asked by other people about a year ago, but nobody answered.
Sounds like a driver issue.
That sounds very strange. I have the same card and can capture 720x480 no problem with VirtualVCR (although the capture window is 704 for this the Philips SAA 7130 chip, so that's what I capture in to keep the aspect ratio correct).
Thanks!
Which verion of VirtualVCR are you using? Mine is 2.6.9.6252.
Are you able to use other software with such resolution or it only works with VirtualVCR? -
1.) VirtualVCR
2.) iuVCR
Those are the 2 most popular and either should work.
Please note I tried this capture card and had an issue with installation that caused all kinds of problems.
I had to uninstall and do it again.
It worked then (for the most part) except I had a drop frame issue but I think that was just some weird voodoo vibe with my particular combo of equipment.
For most people this card works fine and the image quality is most excellent (from my own experience and pics that other people have posted).
- John "FulciLives" Coleman
P.S.
Try to capture to AVI using the HuffyUV codec and of course 16-bit 48k STEREO PCM WAV format for the audio."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
No sound when capturing with KWorld DVD Maker PCI
By ibzomie in forum Capturing and VCRReplies: 1Last Post: 24th Nov 2014, 06:54 -
HELP please Avermedia A316 Mini PCI-E Analog Digital DVB-T TV Card
By Jorocketoz in forum Capturing and VCRReplies: 0Last Post: 26th Jun 2010, 01:05 -
Zealsoft Music DVD Maker question
By mysts in forum Newbie / General discussionsReplies: 9Last Post: 15th Sep 2008, 08:33 -
Cannot Uninstall or Reinstall UltraTV (AverMedia PCI 300 card)
By steve0701 in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2008, 13:36 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 23:18
