What is the best and easy to use free software that can capture still images from a dvd, dvd +r/-r? I downloade VirtualDub once, but I had deleted an inessential file on my computer once and VirtualDub needed it to work.
If you have a sofware dvd player (like PowerDVD), you can use that to captiure stills from a dvd.
Not sure about any freeware apps. You can try Zoom Player. -
I was going to mention media player classic but for some reason (well on my pc anyway) the capture icon is greyed out so you cannot click it.
I downloaded both mediapayer classic which seemed very simple to use, however, the capture option was alos blacked out. The Zoom Player seems kind of difficult to use and it will not even play the disc in the drive.
assign a key in media player classic for the print function, it works for me ..
i make shift+print and alt+shift+print (auto) the key functions in mpc ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Simple, free ATSC capturing software?
By Brad in forum Capturing and VCRReplies: 5Last Post: 25th May 2013, 18:24 -
Capturing still images - keep quality
By CharlesH in forum Capturing and VCRReplies: 1Last Post: 6th Apr 2010, 18:39 -
Capturing and Downloading Images
By Teac23 in forum ComputerReplies: 2Last Post: 21st Dec 2009, 12:04 -
Royalty Free Images / Photos
By opentone in forum Off topicReplies: 6Last Post: 16th Feb 2009, 20:00 -
By Teac23 in forum ComputerReplies: 6Last Post: 27th Nov 2008, 09:52
