9b
    Mar 2005
    since installing this version every time i try to convert a film the pc crashes before completion?? i have never had this problem with any other version (full version by the way) and have been useing it trouble free for a good while now any ideas anyone ?? ps my h/drive seems to be mysteriously filling rather quickly as well could i be getting the image being put somewhere else as well as where it should be??
    Mar 2005
    very strange just used older version and worked fine???????????????????????
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    What kind of run are you doing? normal svcd to dvd or avi or pal to ntsc?
    Mar 2005
    it was a xvid file mate if that helps thx for speedy reply lee
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Mar 2005
    cheers chris will give that a try mate
