I recorded some video using a Dazzle device. One of the audio wires had been crossed with a video feed. I now have a fine picture but a constant static noise over top of the normal audio sound. is there any tool that i might use to remove or limit this interference??
The only thing that may help it is Cool Edit 2000 or Pro. I've removed hiss from cassette tapes before making CD masters. It works well if you fine tune the hiss levels. Be forewarned, you aren't going to end up with the same quality that was transmitted.
Also - if you recorded in stereo the noise may be on one channel only so disconnect that audio channel to watch and hear your video without the noise. You could play it out to another VCR or PC with a video card. If the noise was recorded over ( on the same channels(s) ) as the good audio your S.O.L. Good luck.
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Can't get sound from MPEG in F.C.
By Tom in HD in forum MacReplies: 3Last Post: 14th Jan 2010, 22:40 -
No sound in MPEG
By 12VIBES in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 17th Nov 2009, 04:54 -
Will the QT MPEG-2 Playback addon help my no MPEG audio on vegas problem?
By Nuke Shower in forum Video ConversionReplies: 5Last Post: 9th Apr 2008, 16:01 -
Convert MPEG-TS 5 channel AC3 to h264 x264 sound problem
By TequilaErik in forum ffmpegX general discussionReplies: 0Last Post: 16th Jul 2007, 18:41
