Does anyone know if the Plextor Convertx PX-M402U works with WinDVR from Intervideo. I asked tech support and got no answer from Plextor. Intervideo said if it is not on their compatible list, then they cannot guarantee it will work. Of course, the PX-TV402U is not on the list but ships with WinDVR. I am thinking the PX-M402U is the same thing as the PX-TV402U except without the TV tuner, which I do not need.
Thanks,
Richard
Not sure but the oem stuff from Plextor is usually programmed specific to their units. As an example, Ulead VS 8 SE now shipping with the Convertx works but download trial from Ulead.com does not.
Heard a lot of good things about GB-PVR and it now supports the convertX. I would consider checking it out and it's free! It should do the same thing as WinDVR. I believe it uses the codecs from your Intervideo install. -
I use GBPVR and support by creating funs skins for it. I've used WinDVR and it doesn't work, You could try MainConcepts PVR 1.1.3 instead if you find GBPVR Software Recorder Plugin for WDM cards doesn't work for you as well. I have MainConcepts PVR 1.13 for my Pinnacle PCTV Pro Stereo dbx card and WinTV PVR-150 running GBPVR v0.92.8.
Best Regards,
Tipstir
MediaMVP Supporter
Plextor M402U - Capture Device not recognised (WINDVD and Nero)
By phantomwalker in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2008, 21:52 -
Serious ConvertX Problem
By Kupo in forum Video ConversionReplies: 9Last Post: 12th Jul 2008, 11:22 -
Plextor convertx px-m402u
By TyWelcome in forum Capturing and VCRReplies: 2Last Post: 18th Feb 2008, 22:43 -
Audio problems with Plextor M402U and Virtual Dub
By nrsgzz in forum Capturing and VCRReplies: 4Last Post: 6th Sep 2007, 18:27 -
Plextor M402U
By LeFreak in forum Capturing and VCRReplies: 5Last Post: 6th May 2007, 21:33
