I like my Leadtek Winfast 2000XP Deluxe, but I might pass it on and upgrade to the Expert. Is there much improvement? I know the Expert is 10 vs 8 bit for the Deluxe, but does that really make a difference? Have any of you used both? I just want to capture from cable and my analog camera.
Thanks.
Yes, the consensus is that the expert is visibly better than the deluxe due to 10 bit against 8 bit.
Once you have settled that issue, you may wish to consider other cards than the Leadtek Expert.
Now it gets personal. Good Luck -
Thanks, I wanted to keep it under $50 and I was comfortable with Leadtek. Also, I don't want a mpeg only card.
I have the 2000XP Expert and I'm very happy with it.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Trying to use VirtualVcr with Leadtek Tv2000 expert.
By GLE3 in forum Capturing and VCRReplies: 0Last Post: 20th May 2009, 10:46 -
leadtek PxDVR3200 H - HD component input
By Thalandor in forum Capturing and VCRReplies: 1Last Post: 30th Oct 2008, 21:10 -
What is better than a leadtek expert tv tuner card?
By Gplracer in forum Capturing and VCRReplies: 1Last Post: 7th Jul 2007, 14:44 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
