Results 1 to 12 of 12
  1. Member Gritz's Avatar
    Jan 2003
    I'm trying to capture video from the web using CamStudio and all I get is a black screen with the audio. It will display any other portion of my Desktop ... but not the actual video. GSpot says the video should display with DirectShow .... but it doesn't. I'm probably missing a codec but I've tried viewing with WMP, Winamp, and PowerDVD ... all get the same results. I've tried recording using DivX and Intel Indeo 4.5 too .... and get the same results. I must be missing something pretty basic here?? Any help appreciated.
    "No freeman shall be debarred the use of arms." - THOMAS JEFFERSON .. 1776
    Turn off overlay/hardware video acceleration in wmp under options->performance->video acceleration and drag it to none.
    Or capture with HyperSnap-DX
  3. Member p_l's Avatar
    Montreal, Canada
    Or in CamStudio itself there is a setting to disable hardware acceleration for the duration of the capture.
    What a coincidence, I had this very same problem last night, but checking that option solved it, and the capture included the video.
  4. Member p_l's Avatar
    Montreal, Canada
    I just checked, now that I'm on my home machine, and first, sorry, I was thinking of CamTasia Studio, from the makers of SnagIt, not CamStudio (They do sound alike ).
    For what it's worth, there are two ways to temporarily disable hardware acceleration during a CamTasia Studio capture.
    One is to check the box for that option in the Recording Wizard.
    The other way is, from the CamTasia Recorder menu, choose Tools | Options, then the Capture tab, and check appropriate box there. That way, the option is saved as your default preference.
  5. Member p_l's Avatar
    Montreal, Canada
    Oh, and maybe we could add Camtasia Studio to the Tool list?
  6. Member Gritz's Avatar
    Jan 2003
    Thanks guys, I appreciate the responses. Turning off hardware acceleration in WMP did the trick, although the final result is a little jerky. Probably has to do with my DirecWay bandwidth at this time of day, or my poor 700 MHz computer (500 MHz overclocked). Camtasia Studio looks nice .... but it's a little spendy for my occasional use!
    It seems hardware acceleration would help though, and not hinder. Maybe something to do with sync?
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    i wont add a screen capture tool that cost $300... .
  8. Member p_l's Avatar
    Montreal, Canada
    Yeah, it is quite pricey. There's a free trial, though.
    I wouldn't pay $2500 or $5000 for DVD authoring software, but we have some listed in the Tool section: https://www.videohelp.com/tools?s=2#2 Maybe these are mainly for institutional investors, like companies or schools?
  9. Member p_l's Avatar
    Montreal, Canada
  10. Member Seeker47's Avatar
    Jul 2005
    This is an old thread, but it seemed the one most to the point, and I'm making an effort to research things in the Forums before posting a query that has been dealt with a number of times previously.
    I installed Camstudio 2, but have gone 0 for 2 attempts trying to use it. (The target was an interview clip on HBO Online.) There don't seem to be any guides for it here -- if one is even called for -- and the Help stuff for the program points to dead links. The first attempt was with the site choice of broadband + WM format. I got the black screen with no video and no sound. I had selected sound recording from speaker, in the program's preferences. For the second try, I followed Baldrick's advice quoted above, and went with a site choice of QuickTime format instead. The resulting .AVI now has video, but it's of terrible quality, and still no sound. What next ? On the first try, I had to kill the flashing video window with Taskmanager, as it was very reluctant to close, and was screwing up the open browser and the desktop.
    The one good thing here is that Camstudio is FREE. I would hesitate to spend money on Snagit or AV Screencast, lacking some assurance that they can really do the job. Maybe the better bet is to use the combo of Urlsnooper to locate the original video file, and then Net Transport to grab it, if the site will let you ??
    Edit: Oh yeah, to be complete here, I did install the Camstudio lossless codec, in between the 1st. and 2nd. attempts.
  11. Member Gritz's Avatar
    Jan 2003
    I recently used HyperCam 2 (unregistered shows HyperCam2 overlay) using Video1 and came up with an acceptable recording. For adding sound you might try the 8 bit option and see if it works out.
