Hi all...I am looking for something to crop my captured mpeg2 video. I have a pvr 150 (mce) that I use to capture my home video through s-video. For whatever reason, there is a thin line at the bottom of the screen that looks like distorted video and there are two small black lines on the sides. Regular tv input doesn't do it, so I assume it's outputting from the camcorder like that.
How would I go about cropping the video? I don't like the idea of paying 70 bucks for a single function so freeware is preferred. I was also hoping it would be able to do this without degrading quality. I assume this is possible since I can cut/join the files all day long without re-encoding.
Thx a bunch!
Andy
Andy
You can't crop without reencoding the mpg. Most encoders can crop like tmpgenc plus, mainconcept mpeg encoder.
Do not crop it. If you are capturing from VHS the line on the bottom is probably "overscan". That area will not be shown on your TV set.
Search for overscan here in the forum and you will have more information about it. -
Sweet. Thanks for the info! It's Hi8...Does it apply to that as well? I'll check as soon as i get home tonight to see. That would really brighten my day...
Andy -
The source video doesn't matter, the tv crops about 5% of all kind of video to hide crap.
Cropping MPEG2 File
By brvignesh in forum EditingReplies: 7Last Post: 24th Mar 2008, 13:42 -
Looking For A Cropping/Splitting/Converting Tool that supports MPEG2
By LordOfTheStrings in forum EditingReplies: 21Last Post: 12th Nov 2007, 12:09 -
Capture without any cropping?
By axlish in forum Capturing and VCRReplies: 1Last Post: 5th Oct 2007, 18:22 -
HQ MPEG2 Cropping
By KnightHeart in forum Video ConversionReplies: 3Last Post: 12th Jul 2007, 16:16 -
PVR capture
By boots in forum Capturing and VCRReplies: 2Last Post: 15th Jun 2007, 21:57
