I'm trying to register my copy of ffmepgx, but there is no area to add my key, or any pop up when the app starts. Anyone know how I can fix this problem?
Results 1 to 16 of 16
You should finish the installation of the components by following instructions at http://homepage.mac.com/major4/download.html then you will access to the registration screen.
Send me to major4@mac.com a screenshot of the application when you open it. Do you get the installer screen each time?
I used the install to install them. Maybe I can try and completly remove ffmpegx and then try a completly new install. Anyone know how to completly remove the app?
Email me to major4@mac.com with your reg code and a screenshot of the contents of your /Library/Application Support/ffmpegX folder, and I will suggest you a workaround.
mine did the same thing but I think its because the installer didnt like the mpeg2enc file. When I click on ABOUT ffmpegx is the only one not checked.
ScottZ
Registration Problems
By codfather100 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th May 2011, 07:03 -
Is there a PDF for ffmepgX ?
By midiw in forum ffmpegX general discussionReplies: 3Last Post: 20th Jan 2011, 09:23 -
registration
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2010, 06:20 -
registration
By ki46ej03 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Nov 2009, 04:10 -
DVDs made with ffmepgx
By dlg1989 in forum ffmpegX general discussionReplies: 1Last Post: 11th Feb 2009, 14:05
