alright i'm having nothing but problems this week! yesterday I plugged in a 20gb hard drive to my xp machine to partition/format it using the disk administrator or whatever XP calls it. It came up and asked me about the physical disk i think something like if I wanted to make it a dynamic disk..i said yes to this and set it up as a 20gb (minus formatting space)NTFS partition. I powered off my machine, took the HD out, placed it in a static bag and powered my machine right back on. I went to access my 200gb (Xdrive and I get a blank window that pops up and the machine freezes. I checked the cables, etc..no issues there. After rebooting I went back into disk administrator and my X: shows to be healthy. I can right click from there and go to explore and see all the contents of my x: drive. I can even browse around for a little bit before it locks up.
I tried running chkdsk in safe mode but after about 5 hours it still wasn't done. I went back into normal mode and ran chkdsk again, but from the console this time. It scanned the x: drive and found no errors/bad sectors.
so it seems as though thers something wrong with the way windows is seeing this drive but I don't know what to do other than try to find another big drive, copy everything over using xcopy/robocopy from the command prompt, then re-partitioning/formatting the drive.
any suggestions?
If you wanted to keep it as a separate drive you should of made it "basic". Making it "dynamic" you might have? spanned the drive with your 200GB (making windows wanting to see a 220GB drive).
Anyhow (with only your 200GB installed) first try performing a System Restore, a point prier to your problem. If that does work try Fixmbr and Fixboot using the Windows XP install disc, "recovery console" on the drive. -
thanks! I was hoping there was something like that I could do.
yep I didn't understand exactly what "basic" and "dynamic" meant. Both the 200 and the 20 were set up as "dynamic" so your explanation makes perfect sense to me. I noticed next time I went to disk admin it still showed the 20gb in the list, it just had an x over it cause it was no longer connected. i thought that to be odd because usually once the drive is gone it doesn't show up in disk admin. the dynamic thing is what made it stick around. I did a little more poking around and found this jewel of information:
"Another big difference between basic and dynamic disks is there is no Master Boot Record (MBR) on a dynamic disk. Instead, it stores the layout of the disk volumes in a database stored on the last 1 MB of the disk."
which would be the last 1mb of the 20gb disk!
i'll definitely try your suggestions tonight!
thanks!
How did Skype services get onto my WinXP machine???
By PartingShot in forum ComputerReplies: 3Last Post: 3rd Apr 2011, 19:31 -
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 20:40 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 14:42 -
Hard drive access light keeps blinking...
By ntscuser in forum ComputerReplies: 11Last Post: 2nd Jun 2007, 18:49 -
How can I access files from pioneer 531 hard drive using computer
By hlg1111 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 25th May 2007, 01:08
