Starting next month, Sony will release to consumers the HDR-HC1, “the world's smallest and lightest high-definition camcorder” with full HD resolution with the price tag of $1,700.
Weighing only about 1-1/2 pounds, the model includes a Carl Zeiss lens and Sony's CMOS imaging sensor technology.
Because the CMOS sensor consumes less power, the camcorder can be powered with a smaller battery like the model's supplied InfoLithium® M battery, which delivers about 90 minutes of continuous recording (depending on recording mode).
For quick framing and easy image sharing, the camcorder has a 2.7-inch wide hybrid, touch-panel LCD screen to access menu options. You can switch between 16:9 and 4:3 aspect ratios (in DV mode). Other convenient features include fully automatic controls, an intelligent pop-up flash, and Super SteadyShot® image stabilization.
The camcorder also captures 2.8-megapixel digital still images, which can be stored directly on Memory Stick PRO Duo™ media for transfer to PCs and other devices.
The HDR-HC1 offers a full slate of manual controls, including a 10X optical and 120X digital zoom, zoom ring, zebra pattern, spot focus, white balance and shutter speeds
The unit’s Cinematic mode allows recording video with a “film-like” appearance, while the Shot Transition™ feature allows you to go even further in creating cinematic effects.
Looks like a DCR-HC1000 with a PC1000 LCD screen.
I got 2 DCR-HC1000s and they're a very good camera. You just got to bend your mind around the touchscreen.
Watch this one have a touchscreen too and people will love it, unlike the HC1000. Because it's HD... I hope it's low light and color are better than JVC's.Your miserable life is not worth the reversal of a Custer decision.
HD Mini DV camera suggestion?
By alange5 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 14th Jul 2011, 13:51 -
I need a mini CCD pinhole camera.
By Dittoz in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2009, 21:20 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
Capturing widescreen video from Mini DV camera
By eisfeld in forum Capturing and VCRReplies: 7Last Post: 23rd Jul 2008, 20:46 -
Sony Mini-DV camera glitch, what is causing this?
By tarrickb in forum Capturing and VCRReplies: 8Last Post: 25th Nov 2007, 21:41
