Earlier you described the picture as 'grainy'. This is normal with most consumer DV camcorders if the light level is a bit low. As the shot you have posted is taken inside a bus, the subject may have been a bit lacking in light (in the shade). This would explain the noise on the picture which shows up as looking like the grain on high speed film. This noise give the mpeg encoder a hard time and requires a very high bitrate, higher than the DVD spec allows.
As edDV has already explained, if this had been shot professionally as a scene in a film, there would have been much more light aimed at the speakers face.
Results 31 to 32 of 32
Getting larger files than expected using Xvid to compress AVI
By pronco in forum Capturing and VCRReplies: 50Last Post: 7th Sep 2011, 10:42 -
Error: File shorter than expected
By justin79 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Jun 2011, 22:55 -
Just get rid of interlace problems, no good quality expected
By TheOtherSwede in forum Video ConversionReplies: 8Last Post: 13th May 2009, 14:16 -
Report: FCC expected to rule against Comcast
By TaoTeWingChun in forum Latest Video NewsReplies: 1Last Post: 28th Jul 2008, 09:52 -
mpeg2 to mpeg2 lower quality...
By zovx in forum DVD RippingReplies: 4Last Post: 6th Feb 2008, 16:36
