Which do you thinks better Tmpegenc or panasonic?
HOW TO VOTE:
Simply post either: T=tmpegenc or P=Panasonic mpeg encoder
DO NOT:
Leave your signature or put anything else in the post just write T or P.
The winner will be announced soon.
Baker,
Results 1 to 24 of 24
T
<font size=-1>[ This Message was edited by: VCDsMakeMoney on 2001-12-16 01:23:56 ]</font> -
sadly the winner was tmpegenc
Why do u people use tmpegenc when the quailty in panasonic is about the same and there are less blocks ?????
Please post your comments now.
Baker -
TMPGEnc can be tweaked to make MPEGs that match Panasonic's MPEGs. All Panasonic does is soften block noise automatically, and doesn't let you disable it.
irc.webmaster.com port 6667 #DDR -
I am afriad that after testing using a tv out card I found that tmpegenc is a lot worse compared to panasonic than u might think. Also a new version of pwi is coming out soon. u guys should try my guide, baldwick should be posting it soon.
Baker -
baker, it is your subjectiv opinion and that is OK. You can only compare TMPG and PWI, if you make a VCD. TMPG can do a lot more. It is simply a matter of taste, whether some one prefer PWI or TMPG.
You asked for a vote, you got it (some very experienced guys gave you the vote). Do you think, all these guys are wrong? -
TMPGEnc is better on my wallet and is what I am now familiar with. I started on this site just as the Japanese version was released and I had to have the translator file. I started down that path because of price. I get good results so if it's not broke don't switch.
I have to agree I understand y people say tmpegenc is better.
more options,more speed, mpeg 2 encoding E.T.C But for a standard vcd you just can't beat panasonic. Well I enjoyed this vote, I will still use panasonic of course but will on occasion use tmpegenc.
A happy with his final decision
Baker -
Panasonic creates blurry and soft VCD's and does not have the crispness and sharpness of Tmpgenc...
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Well, but TMPG encoded MPEG look "blocky" sometimes. I never noticed that, when I used PWI. As mentioned, it's a matter of personal taste.
Deserves to be a Sticky - Gets my vote
By bendixG15 in forum FeedbackReplies: 3Last Post: 11th Apr 2009, 18:34 -
x264 VAQ Blind Tests - Please vote
By Razorholt in forum Off topicReplies: 0Last Post: 12th Apr 2008, 00:02 -
why can i vote again on same poll?
By TooLFooL in forum FeedbackReplies: 15Last Post: 19th Jul 2007, 06:09
