I extracted audio from a video file and tried to convert the video with TMPGEnc, but when using the wav as the audio file it slows down to where it says it will take 12+ hours to do a 700mb file.
When I do it using the video as the audio source it works fine.
I have Virtual Dub 1.5 10 build 18160
TMPGEnc 2.521.58.169
Why are you trying to encode in TMPGenc with the .WAV?
I encode the .WAV to .AC3 separately using ffmpegGUI, and then author the DVD with the .m2v (video) from TMPGenc and the .AC3.
You just need to make sure that the sample rates and bitrates for the audio match between TMPGenc and ffmpegGUI (I use 48000/256 for both), and then the resulting file sizes will match also.
I then encode m2v+mp2 in TMPGenc, and discard the .mp2 file in favor of the .AC3 before authoring.
I do any corrective work to the .WAV (declicking, noise reduction, amplitude correction, enhancement, etc.) before encoding to .AC3.
C.K.
Virtualdub kernel32 error, TMPGEnc cutting video
By koberulz in forum Newbie / General discussionsReplies: 5Last Post: 11th Apr 2012, 11:36 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Windows Color Profiles ignored by TMPGenc, VirtualDub, etc. ?
By sanlyn in forum Video ConversionReplies: 13Last Post: 28th Jun 2008, 09:42 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
