I just converted a avi xvid to DVD-R, and the audio is out of sync.
Now I read some where to Demultiplex using Tmgnec but it didn't sy how.
Can some one please tell me the steps for this?
I converted the audio using vdub to wave then used tmg to convert the wave in to a mp file with the video dvd as normal.
thanks
Why dont you check out my guide on how to use virtualdub to frameserve the video to av2mpeg , its easy to do , and you get mpeg2 in dvd format out at the end and the audio should still be in sync .
It wont help you resync , but there's another trick I use in virtualdub for that , but it takes time ... thats why its not in the guide
Command line tool to demultiplex video
By lovyagin in forum EditingReplies: 6Last Post: 20th Dec 2009, 13:43 -
demultiplex and multiplex ..........HELP!
By efiste2 in forum DVD RippingReplies: 1Last Post: 21st Jul 2007, 18:01
