If I want to encode it at 352x480 so it will be compatible with DVD in the future, how do I make this change in DVD2SVCD?
Under the frameserver tab check "Edit the Avisynth Script File."
Before it starts encoding it will let you edit the script. Depending on your settings you might have something different but look for a line like
BicubicResize(480,400,0,0.75)
Change it to BicubicResize(352,400,0,0.75)
Possible to change ref frame value w/out recoding?
By dave in or in forum Video ConversionReplies: 4Last Post: 2nd Aug 2011, 20:11 -
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 14:13 -
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 14:04 -
Help with understanding when to change frame rate
By mlaran in forum Video ConversionReplies: 3Last Post: 22nd Feb 2010, 10:11 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 05:21
