Some times video doesnt play full screen. I want to stretch it to full screen but dont want to mess up quality when i play on stand a lone dvd player, how can i do this ?
Results 1 to 12 of 12
ANDOriginally Posted by DSM4Life
dont want to mess up qualityCannot be done.how can i do this ?
However, you CAN use the ZOOM feature of the player. Or crop and re-encode. But quality loss happens, no way around it.Want my help? Ask here! (not via PM!)
By full screen I assume you mean the 4:3 format? If you don't mind people looking very tall and thin, it can be done by just setting your DVD player to 16:9 screen mode. No loss of quality there, just mucking around with the aspect ratio.
If you're talking about making a Letterbox movie Full Screen, then that would require reencoding and zooming in, which will always lose quality. It can be done using any number of Encoding programs like TMPGEnc or Vegas, Premiere, etc."*sigh* Warned you, we tried. Listen, you did not. Now SCREWED, we all will be!" ~Yoda -
If the "black bars" are viewable whrn you play it on a computer, or in other words it's part of the video you have to crop it.Originally Posted by DSM4Life
can you help me on how i do that ? What program you recommend ? sorry i am new to this...
You can set your player to force pan and scan. This means that for all 16:9 DVDs you will see full screen, but only see the centre. Anything that happens to the side will be missed by you. This won't help disks that are already 4:3 letterbox.
When you view this on the computer, what do you use ? Depending on your settings, window media player will show the black borders even when they are not in the original. Try using something like virtualdubmpeg or virtualdubmod to see if the borders exist.Read my blog here.
i found this on another post from you "settings->advanced->source aspect ratio:16:9 and video arrange method: full screen (keep aspect ratio).Originally Posted by Baldrick
check it with file->preview to see that it looks okey. "
i did that but when i go into preview it comes up blank with nothing to view ? -
By this I'm assuming they are part of the video, setting the aspect is not going to help because the black areas are part of the video. The only way to remove them is to crop them from the video. I think Virtualdub will do that but I'm not certain because I don't use it. Do a search for cropping.Originally Posted by DSM4Life
The only other alternative is as suggested above zoom in with your DVD player. -
change the directshow property, read www.videohelp.com/tmpgenc#problems
Stretch mp4?
By yams in forum Video ConversionReplies: 0Last Post: 13th Nov 2010, 21:49 -
Youtube 4:3 stretch
By mitchellrichard in forum Newbie / General discussionsReplies: 1Last Post: 8th Nov 2010, 05:22 -
can i stretch this video?
By uglijimus in forum Video ConversionReplies: 9Last Post: 10th Oct 2009, 00:02 -
Help to stretch video
By adhouse13972 in forum Video ConversionReplies: 8Last Post: 7th Jan 2009, 14:06 -
Toshiba SD-KP19 Screen Stretch Question
By danmanx in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Aug 2007, 16:31
