I'am planning 2 purchase one of these because i would like 2 capture programs and output them to mpg vcd and output current movies to vhs.
ANyways my question is. Say I have a downloaded divx movie. I would need 2 convert it into the mpjpeg format and then i would record it back to the vcr? right?
Would this yield good quality results?
Would the convertion process to mpjpeg take a long time?
thanks
AnonymousGuest
Yes, you would need to convert the files into mjpeg before recording them to the vcr.
Quality of mjpeg can be adjusted, but it takes more space to get higher quality. The quality of the VHS recording can be just as good as the source DivX or mpeg file.
Converting should be fast, depending on how long it takes to decompress the source video. If your computer can play the file in real-time, it should be able to convert it in about the same amount of time.
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 04:03 -
Software for S-video output on Pinnacle DC10 plus card(XP)
By Eightbitgnosis in forum Software PlayingReplies: 2Last Post: 30th Jan 2010, 10:33 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 15:54 -
Pinnacle AV/DV2 or DC10+B miserable performance
By cybertheque in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2008, 22:44 -
Pinnacle DC10 Plus on Windows XP
By Paulsa in forum Capturing and VCRReplies: 0Last Post: 3rd Apr 2008, 11:02
