Hello all,
I am new to this forum. Can someone tell me which software is better when it comes to shriking the DVDs. I had read DVD rebuilder is better if you doing a large backup. Does it really matter which software I use? DVD shrink or DVD-Rb?????
'Best' is a matter of opinion !
It is probably better if you test these two pieces of software out yourself and come to your own conclusions.
Every individual has there own thoughts and preferences on what is best so you will probably end up getting several different answers.
It also depends on what you are playing/watching your backed up movies on.
I personally use DVDshrink, I do a main movie only backup keeping the main menu and I find it extremely difficult to notice any difference in quality from the original, even with a large amount of compression, and I'm very fussy about picture quality !
I also have quite a high end home cinema setup which gives great quality.
PS I haven't used DVD-RB so I cant give my opinion on this. -
I use DVD Rebuilder all the time. I bought Cinema Craft Encoder Basic and the quality is awsome. I've backed up dvd's being compressed over 50% and they are sharp & crystal clear. With DVD Rebuilder you can backup 2 movies to a DVD5 with no quality loss, I do this all the time.
Hope this helps,
BungiNuts -
Take a look at some of the comments made about these two pieces of software in the TOOLS section, this may give you more of an insight to what people think of them,
DVDshrink,
https://www.videohelp.com/tools?tool=DVD_Shrink
DVD-RB,
https://www.videohelp.com/tools?tool=DVD_Rebuilder
Actually, at least one guy took this question very seriously and designed a quite excellent test on it. Read this:
http://forum.doom9.org/showthread.php?s=&threadid=91418
Conclusion: DVD-RB hands down the winner. -
Originally Posted by normcar
I've tried DVD-RB w/QuEnc and it took over 5-hours to run. For the same project, DVD-RB w/CCE Basic took around 2-hours. I noticed no difference in the quality.
ReJig is a transcoder and not an encodered. So, DVD-RB w/ReJig is comparable to DVD-Shrink.
By the way, for me CCE-basic was well worth the $58. I now use it as my encoder of choice over TMPGEnc Plus.
Audio issue when shrinking blu ray to dvd using BD-Rebuilder or DVD-Rebuild
By sharjohn in forum Blu-ray RippingReplies: 2Last Post: 1st Dec 2010, 12:36 -
DVD in BD Rebuilder!!!
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 18th Aug 2009, 10:22 -
dvd rebuilder
By dvd1304 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2009, 12:31 -
DVD-Rebuilder and HCenc 0.23?
By stiltman in forum DVD RippingReplies: 1Last Post: 17th May 2008, 22:59 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
