  1. I'm running Win XP with a decent DVD/CDR burner (don't have the exact make off the top of my head). It's been working fine for about 18 months. I usually encode AVI files of various TV shows into MPEG-1/VCDs so I can watch them on my DVD set-top box downstairs with my wife.
    Now, I don't get fancy with this. In fact, I usually just use NERO 6 to do the encoding and to author a very simple menu. I don't even bother with chapter breaks.
    A few days ago I began to have a WEIRD problem. Encoding with NERO takes a long time so I usually leave the room and do other things while it's working. The other day I set up a VCD, left the room, and then much later heard this LOUD HIGH-PITCHED SQUEAL. I went back to the computer and the screen was dark and this LOUD sound was coming from the CPU box. The whole system was unresponsive so I had to power-down to stop it.
    Since then, it's done this a two more times. Once while I was trying a new encoding app, and another while working with Nero. As I said, this is a new problem on a system that (according to all my spyware scans) is virus & Spyware free and has been running for more than 18 months.
    Any thoughts on this?
    Mike
  2. Member normcar's Avatar
    Aug 2003
    USA - IL
    I would use the HD utilities for your HD to check to see if it is failing. The noise may also be a fan, which may be running faster when the temp climbs, but probably not if it rarely happens.
    Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
  3. It's definitely not a fan noise, but I'll run a check on the HD. I doubt that's it, though -- no other symptoms and this isn't the only processor intensive activity I do. Nevertheless, the HD scan is a good idea.
