Hello all,
When opening my TV Captures in VirtualDubMod, I cut out the commercials and other things I do not want. Then, I go to the stream list and save a WAV file of the audio (PCM). I use BeSweet to convert it to an 128kb/s VBR mp3 file. Then, I insert that stream into the video via VirtualDubMod's stream list. I compress with XviD 2-pas. However, on the second pass, the progress just stops at 93% (or somewhere close to that) and it acts like it's done (the percent done becomes gray and the status shows Done). So, I open the file and the Audio and Video are not in sync and the whole file doesn't play. Does anyone know why?
You might try using CBR instead of VBR in your MP3 encoding. I have nothing but problems with VBR audio encodes and Xvid and with your type of audio, the file size should not be too much bigger.
guns1inger, I agree with your assessment. Can you or somebody explain why MP3 VBR causes so many problems, so I can use this for future reference? Sorry if I missed a good explanation before, direct me to a thread if you can.
VDubMod Oversize Files
By NeroLi8gerzid in forum Video ConversionReplies: 2Last Post: 6th Oct 2011, 05:16 -
can't open any videos in vdubmod 1.5
By mr-scarface in forum EditingReplies: 8Last Post: 18th May 2009, 04:53 -
having trouble adding permanent subs wtih vdubmod
By myname77 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Nov 2008, 09:08 -
editing videos with vdubmod
By aruwin in forum EditingReplies: 1Last Post: 17th Oct 2008, 12:16 -
vdubmod crash
By RobMan in forum SubtitleReplies: 4Last Post: 31st Dec 2007, 08:22
