    Jan 2003
    Nassau, Bahamas
    can someone please help me locate or tell me what core and max CPU i can purchase for the asus p4p800 se mobo. i just bought one brand new, i wanna put a 3.2 ghz processor in it, but i dont know what core in can handle with that speed...can someoneplease help me out
    "If u cant eat it - u dont need it"
    "Baby - If i dont hit it, Who will?"
    "Why is Abbreviation such a long word"?
  2. Member normcar's Avatar
    Aug 2003
    USA - IL
    All you need to know, is that the CPU should be for a 478 socket. There are several different 'cores' which are 478 sockets. I would suggest the 3.2 with 512KB Cache (Northwood) http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80663 . The 3.2 with 1MB cache (Prescott) requires a very good CPU cooler because of the extra heat but does not significantly increase throughput. If you are going to do video processing or gaming, you should upgrade your CPU cooler. I recommend the XP-90 cooler. It is considered the best non-water cooling CPU cooler.
    Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Google is your answer or check out the Asus Website.
    It supports up to 3.2GHz, 800MHz FSB.
    Jan 2003
    Nassau, Bahamas
    yeah but im specifically asking about what core cpu, northwood, williamette, prescott...the reason being, i know some mobo can handle a prescott 3.0 highest, then can handle a williamette 3.2...i wanna know which one so i could purchase the highest and fastes processor
  5. Asus web should have a list of compatible cpu's for your board revision.
    Jan 2003
    Nassau, Bahamas
    thats just it, im unable to find it, can someo ne point me to it
  7. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    the ASUS P4P800SE can use either a NORTHWOOD or PRESCOTT CPU up to 3.2GHZ according to the ASUS website.
    http://usa.asus.com/prog/spec.asp?m=P4P800%20SE&langs=09
    i agree with normcar to get a NORTHWOOD PENT 4 3.2GHZ, 800 FSB. if you get a PRESHOT (PRESCOTT) chip you'll need to invest in a good CPU cooler.
    Jan 2003
    Nassau, Bahamas
    THANKS....thats what i wanted to know
