Results 1 to 9 of 9
  1. Banned
    May 2005
    uk
    HI. IM BACKING UP MY DVDS AND WANT TO PACKAGE THEM GOOD. IM LOOKING FOR THE DIGIBOX THAT FOLD OUT DVD SIZE. I CAN GET THE DISK HOLDERS THAT YOU WOULD STICK ON I JUST NEED TO BUY THE CARDBOARD BACKING THAT HAS ALL THE RIGHT SIZES AND AND FOLDS.ALSO LOOKNIG FOR DVD BOOX JACKETS FOR ALL SIZES OF DVDS. I WOULD NEED TO PRINT THE IMAGES ON SO THEY HAVE TO COME FLAT READY TO ASSEMBLE. CAN ANYBODY HELP ME.P.S I WOULD ALSO NEED SOME DESIGN SOFTWARE THAT WOULD UNDERSTAND THE MATERIAL IT IS PRINTING ON SO WOULD GET THE JOB DONE.THANKS[/b]
    dont ask what a dvd can do for you
    ask what you can do for a dvd
    Apr 2004
    Miskatonic U
    Please, don't shout. Posting in all capitals is considered shouting, and extremely rude. Cheers.
    Read my blog here.
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Please do not use this key:
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Look out!
    ... it's the Punctuation Police
    If in doubt, Google it.
  5. Member e404pnf's Avatar
    Dec 2004
    Warmington on Sea
    I not sure if I'm reading your question correctly, but is this the sort of thing you are after http://www.blankdiscshop.co.uk/acatalog/labelling.html {PA 6029}?
    If not have a good look around these sites that offer great deals in the UK...
    http://www.ebuyer.co.uk and
    http://www.dabs.com/uk
    - e404pnf
  6. Banned
    May 2005
    uk
    hi, soz about the capital letters i has no idea it was called shouting.anyway. i have looked at the sites everyone gave me,(thanks alot)but still turned upp with the same old multi boxes. what i am looking for is, have you ever seen the star trek or smallville boxsets uk edition. they are all in 1 straight line and fold up to the widht of 1 dvd.p.s does anyone know of an easy (single program)that converts ntsc to pal. i have read all the stuff about changing vob files or whatever but just a program where i put the disk in and then it does the magic and then i put in a blank and write it and then i effectively have a region 2 that is compatible with pal tv's and r2 players
    thanks alot guys'
    p.s dont you think kill bill is alittle like star wars
  7. And it was going to be in bold!!
    If blankdiskshop aint got it, maybe try neato or a "Local" shop (LOG)
    Ps .. with added swearing, better dialogue and adult themes?
    The electronic components of the power part adopted a lot of Rubycons.
  8. Banned
    May 2005
    uk
    hi, i made a break through. on 99% of uk sites they have multi-boxes which are not the best of quality but in america they have alphs paks which are the equivilant of amaray in the uk. these alphapak can hold up to 8 discs and are deffinatly a great find on a uk website
    p.s i meant they are similar because they both try and show you something to think it is the climate or something important but then you find out it is infact much easier to win or less important to the characters after what they have just been through.
    in kill bill opening fight with vivica fox you think it is a close fight and anyone can win but then you see when she croses her name of her kill list that she has infact killed lucy lue already and once you see the huge fight in japan you realise if she can do all this do you think vivica fox had stood a chance against her. with star wars the last 3 seeing those batlles thinking they were big and huge then you see episode 2&3 and realise that these were the big battles and later batles in episodes 4,5,6 were no way near the scale
