what is the best way to add sud to a movie . Right now i use TMPGEnc Xpress to convert to mpg then put it in nero to transcode it , then burn it . What would i do to what i do.
Add sub to what? An XviD avi? XviD mp4? Add subs whilst converting an avi to an mpg? Convert something to DVD and add a seperate subtitle stream?
What exactly are you asking? -
Well if you are using TMPGEnc to encode an mpg, then either frameserve using AVISynth (better) or VirtualDub or use ffdfshow to decode and enable subs.
Nero to transcode? Get it right the first time and you don't need to do that. Also if you final destination is DVD Video, then you can add the subs as a seperate stream rather than hard encoding them.
Lastly, subs have been covered numerous times in the forum already and probably also in the guides.
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 04:02 -
adding subtitles to AVI (xvid or divx) WITHOUT re-compressing
By truthlesshero in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 11:43 -
Adding file information to an avi/xvid file
By budman643 in forum Newbie / General discussionsReplies: 3Last Post: 10th Aug 2009, 15:21 -
Adding subtitle to xvid without increasing file size of the .avi?
By Kromgol in forum Newbie / General discussionsReplies: 3Last Post: 19th Jul 2009, 13:03 -
Trouble adding permanent subtitle to xvid, subs don't break right
By boblydan in forum SubtitleReplies: 8Last Post: 18th Jul 2008, 20:53
