and whoever converted from NTSC to PAL just made it totally wrong, so the version on my PAL VHS has the following errors:
Colours disappear completely at times; if colour IS visible then its mainly the white noise chaos stuff.
There are horizontal lines all over the screen for most of the time
I've seen stuff like this before: When I have an NTSC tape and play it back in a player that isnt really NTSC compatible then it looks almost the way the stuff on my PAL VHS tape looks.
So now I only have the fucked up PAL tape. any way to repair the thing and at least get some of the horizontal lines out of it?
any idea how to un-ruin a NTSC-PAL conversion thats already been done?
There is very little you can do. There are a couple of avisynth filters that *might* be able to remove some of the noise - despot and it's brother (can't remember the name, sorry). But at best they will give you a blurry line instead of a sharp white one. It sounds like a combination of poor format playback and possibly even macro-vision interferance as well. No chance of getting the original tape ?
Read my blog here.
Just convert it to pure B&W and be done with it.
Or look into getting back the original tape.Want my help? Ask here! (not via PM!)
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
How to convert a PAL VHS into NTSC VHS or DVD?
By coody in forum Video ConversionReplies: 9Last Post: 22nd May 2011, 03:09 -
Pal S-VHS to NTSC PC
By Jerry1964 in forum Capturing and VCRReplies: 14Last Post: 19th Aug 2008, 09:50 -
NTSC VHS to PAL DVD Via DVD VHS Combi
By wozmac in forum DVD & Blu-ray RecordersReplies: 7Last Post: 6th Jun 2007, 02:16
