  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hey everyone, i am trying to play my NBA LIVE 2005 on my PC and i have CloneCD installed so im gettin a YOU CAN'T PLAY THIS GAME BECAUSE THERE IS AN EMULATION DEVICE blah blah. ive already disabled Deamon, now i need to know how to disable CloneCD's emulation, any adivce? thanks
    Wow! You got shocks, pegs... LUCKY!
  2. Its not Clone CD itself I don't believe, its the image drive being active that usually causes this. I haven't had CCD installed in a while. You'll have to look for how to disable or uninstall it's image drive.
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok
    that makes ense, i had this same problem when i peviously had CCD, and i ended up uninstalling it, i mite just do the same again, other programs can do wat it does without the hassle, thanks again
