I'm encoding my videos in MPEG2 9464 kbps and audio in 336 kbps which totals to 9800 kbps DVD standard size.
I was wondering if it's possible to encode video in (non dvd standard) more than 9800kbps.
If yes
- would i see any quality difference?
- what bad side effect does it have on playback?
- What programs allow me to do it? I use TMPGEnc DVD Author
- How can I check how much Bitrate does the menu use?
thanks in advance
1. No
2. Freezing
3. Dont know
4. Demux the VTS_01_0.VOB with pgcdemux and open with bitrate viewer -
it is, but it's not recommended.
the quality is better, but you won't see the diference.
