  1. Hey guys, I am currently learning adobe after effects, and I already use premiere pro. Anyways, I installed after effects, and now some of my avis wont play. I then installed the klite codec pack to see if that would fix it, but still same just a black screen on some avis. Is there a piece of software that will test my machine and tell me what codecs are working and what isnt? Is there another codec pack i should install instead?
    Youll understand when im dead
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    First...you shouldn't use codec packs. Just use a program such as gspot to check the video in question...it will tell you what codec is needed.
    Then all you need to do is install that codec.
    I believe there is a program called codec sniper or something similar that will checked the installed codecs.
    Google is your Friend
  3. BI_RGB Raw Bitmap 4cc = MSVC(_RGB) ------ thats what gspot says it is... It also says no codec needed... codec sniper says they are all ok. Any ideas?
    Thanks, John
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    There is a codec list here: http://www.fourcc.org/index.php?http%3A//www.fourcc.org/rgb.php
    MSVC is the actual codec name. It is a standard M$ codec...maybe yours is corrupt.
